ONTAP Select
JSON per lo script per creare un cluster ONTAP Select
Collaboratori netapp-revathid
Quando si crea o si elimina un ONTAP Select cluster utilizzando gli esempi di codice Python, è necessario fornire un file JSON come input allo script. È possibile copiare e modificare l'esempio JSON appropriato in base ai propri piani di implementazione.
cluster a nodo singolo su ESXi
  "hosts": [
      "password": "mypassword1",
      "name": "host-1234",
      "type": "ESX",
      "username": "admin"
  "cluster": {
    "dns_info": {
      "domains": ["lab1.company-demo.com", "lab2.company-demo.com",
        "lab3.company-demo.com", "lab4.company-demo.com"
      "dns_ips": ["10.206.80.135", "10.206.80.136"]
      "ontap_image_version": "9.7",
      "gateway": "10.206.80.1",
      "ip": "10.206.80.115",
      "name": "mycluster",
      "ntp_servers": ["10.206.80.183", "10.206.80.142"],
      "ontap_admin_password": "mypassword2",
      "netmask": "255.255.254.0"
  "nodes": [
      "serial_number": "3200000nn",
      "ip": "10.206.80.114",
      "name": "node-1",
      "networks": [
          "name": "ontap-external",
          "purpose": "mgmt",
          "vlan": 1234
          "purpose": "data",
          "vlan": null
          "name": "ontap-internal",
          "purpose": "internal",
          "vlan": null
      "host_name": "host-1234",
      "is_storage_efficiency_enabled": false,
      "instance_type": "small",
      "storage": {
        "disk": [],
        "pools": [
            "name": "storage-pool-1",
            "capacity": 4802666790125
cluster a nodo singolo su ESXi utilizzando vCenter
  "hosts": [
      "name":"host-1234",
      "type":"ESX",
      "mgmt_server":"vcenter-1234"
  "cluster": {
    "dns_info": {"domains": ["lab1.company-demo.com", "lab2.company-demo.com",
      "dns_ips": ["10.206.80.135","10.206.80.136"]
  "ontap_image_version":"9.7",
  "gateway":"10.206.80.1",
  "ip":"10.206.80.115",
  "name":"mycluster",
  "ntp_servers": ["10.206.80.183","10.206.80.142"],
  "ontap_admin_password":"mypassword2",
  "netmask":"255.255.254.0"
  "vcenter": {
    "password":"mypassword2",
    "hostname":"vcenter-1234",
    "username":"selectadmin"
  "nodes": [
      "ip":"10.206.80.114",
      "name":"node-1",
      "networks": [
          "name":"ONTAP-Management",
          "purpose":"mgmt",
          "vlan":null
          "name": "ONTAP-External",
          "purpose":"data",
          "vlan":null
          "name": "ONTAP-Internal",
          "purpose":"internal",
          "vlan":null
      "storage": {
        "disk":[],
        "pools": [
            "capacity":5685190380748
cluster a nodo singolo su KVM
  "hosts": [
      "name":"host-1234",
      "type":"KVM",
      "username":"root"
  "cluster": {
    "dns_info": {
    "name":"CBF4ED97",
  "nodes": [
      "serial_number":"3200000nn",
      "name": "node-1",
      "networks": [
          "purpose": "mgmt",
          "vlan":1234
          "purpose": "data",
          "vlan": null
          "vlan": null
      "storage": {
        "disk": [],
        "pools": [
