Privilegi minimi vCenter richiesti
Collaboratori netapp-revathid
Prima di iniziare la distribuzione del SnapCenter Plug-in for VMware vSphere, è necessario assicurarsi di disporre dei privilegi minimi richiesti per vCenter.
Privilegi richiesti per il ruolo di amministratore di vCenter
Datastore.AllocateSpace Datastore.Browse Datastore.Delete Datastore.FileManagement Datastore.Move Datastore.Rename Extension.Register Extension.Unregister Extension.Update Host.Config.AdvancedConfig Host.Config.Resources Host.Config.Settings Host.Config.Storage Host.Local.CreateVM Host.Local.DeleteVM Host.Local.ReconfigVM Network.Assign Resource.ApplyRecommendation Resource.AssignVMToPool Resource.ColdMigrate Resource.HotMigrate Resource.QueryVMotion System.Anonymous System.Read System.View Task.Create Task.Update VirtualMachine.Config.AddExistingDisk VirtualMachine.Config.AddNewDisk VirtualMachine.Config.AdvancedConfig VirtualMachine.Config.ReloadFromPath VirtualMachine.Config.RemoveDisk VirtualMachine.Config.Resource VirtualMachine.GuestOperations.Execute VirtualMachine.GuestOperations.Modify VirtualMachine.GuestOperations.Query VirtualMachine.Interact.PowerOff VirtualMachine.Interact.PowerOn VirtualMachine.Inventory.Create VirtualMachine.Inventory.CreateFromExisting VirtualMachine.Inventory.Delete VirtualMachine.Inventory.Move VirtualMachine.Inventory.Register VirtualMachine.Inventory.Unregister VirtualMachine.State.CreateSnapshot VirtualMachine.State.RemoveSnapshot VirtualMachine.State.RevertToSnapshot
Privilegi richiesti specifici per il plug-in SnapCenter per VMware vCenter
* Privileges*
Etichetta
netappSCV.Guest.RestoreFile
Ripristino file ospite
netappSCV.Recovery.MountUnMount
Montare/Smontare
netappSCV.Backup.DeleteBackupJob
Elimina gruppo di risorse/backup
netappSCV.Configure.ConfigureStorageSystems.Delete
Rimuovere i sistemi di archiviazione
netappSCV.View
Visualizzazione
netappSCV.Recovery.RecoverVM
Recupera VM
netappSCV.Configure.ConfigureStorageSystems.AddUpdate
Aggiungi/modifica sistemi di archiviazione
netappSCV.Backup.BackupNow
Esegui il backup ora
netappSCV.Guest.Configure
Configurazione ospite
netappSCV.Configure.ConfigureSnapCenterServer
Configurare SnapCenter Server
netappSCV.Backup.BackupScheduled
Crea gruppo di risorse
