Come cambiano le impostazioni dell'intero host durante l'installazione
Collaboratori netapp-lhalbert
Nei sistemi bare metal, StorageGRID apporta alcune modifiche all'intero host sysctl impostazioni.
Vengono apportate le seguenti modifiche:
# Recommended Cassandra setting: CASSANDRA-3563, CASSANDRA-13008, DataStax documentation
vm.max_map_count = 1048575
# core file customization
# Note: for cores generated by binaries running inside containers, this
# path is interpreted relative to the container filesystem namespace.
# External cores will go nowhere, unless /var/local/core also exists on
# the host.
kernel.core_pattern = /var/local/core/%e.core.%p
# Set the kernel minimum free memory to the greater of the current value or
# 512MiB if the host has 48GiB or less of RAM or 1.83GiB if the host has more than 48GiB of RTAM
vm.min_free_kbytes = 524288
# Enforce current default swappiness value to ensure the VM system has some
# flexibility to garbage collect behind anonymous mappings. Bump watermark_scale_factor
# to help avoid OOM conditions in the kernel during memory allocation bursts. Bump
# dirty_ratio to 90 because we explicitly fsync data that needs to be persistent, and
# so do not require the dirty_ratio safety net. A low dirty_ratio combined with a large
# working set (nr_active_pages) can cause us to enter synchronous I/O mode unnecessarily,
# with deleterious effects on performance.
vm.swappiness = 60
vm.watermark_scale_factor = 200
vm.dirty_ratio = 90
# Turn off slow start after idle
net.ipv4.tcp_slow_start_after_idle = 0
# Tune TCP window settings to improve throughput
net.core.rmem_max = 8388608
net.core.wmem_max = 8388608
net.ipv4.tcp_rmem = 4096 524288 8388608
net.ipv4.tcp_wmem = 4096 262144 8388608
net.core.netdev_max_backlog = 2500
# Turn on MTU probing
net.ipv4.tcp_mtu_probing = 1
# Be more liberal with firewall connection tracking
net.ipv4.netfilter.ip_conntrack_tcp_be_liberal = 1
# Reduce TCP keepalive time to reasonable levels to terminate dead connections
net.ipv4.tcp_keepalive_time = 270
net.ipv4.tcp_keepalive_probes = 3
net.ipv4.tcp_keepalive_intvl = 30
# Increase the ARP cache size to tolerate being in a /16 subnet
net.ipv4.neigh.default.gc_thresh1 = 8192
net.ipv4.neigh.default.gc_thresh2 = 32768
net.ipv4.neigh.default.gc_thresh3 = 65536
net.ipv6.neigh.default.gc_thresh1 = 8192
net.ipv6.neigh.default.gc_thresh2 = 32768
net.ipv6.neigh.default.gc_thresh3 = 65536
# Disable IP forwarding, we are not a router
net.ipv4.ip_forward = 0
# Follow security best practices for ignoring broadcast ping requests
net.ipv4.icmp_echo_ignore_broadcasts = 1
# Increase the pending connection and accept backlog to handle larger connection bursts.
net.core.somaxconn=4096
net.ipv4.tcp_max_syn_backlog=4096
