データの特定の日付ベースのスキャンおよびコピー
この解決策は、特定の日付に基づいてデータをコピーする必要があるお客様を対象としています。次の情報を確認します。
Created a file in Y: and checked the scan command to list them. c:\XCP>dir Y:\karthik_test Volume in drive Y is from Volume Serial Number is 80F1-E201 Directory of Y:\karthik_test 05/26/2020 02:51 PM <DIR> . 05/26/2020 02:50 PM <DIR> .. 05/26/2020 02:51 PM 2,295 testfile.txt 1 File(s) 2,295 bytes 2 Dir(s) 658,747,392 bytes free c:\XCP> c:\XCP>xcp scan -match "strftime(ctime,'%Y-%m-%d')>'2020-05-01'" -fmt "'{},{}'.format(iso(mtime),name)" Y:\ XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to Calin Salagean [NetApp Inc] until Mon Dec 31 00:00:00 2029 It appears that you are not running XCP as Administrator. To avoid access issues please run XCP as Administrator. 2020-05-26_14:51:13.132465,testfile.txt 2020-05-26_14:51:00.074216,karthik_test xcp scan -match strftime(ctime,'%Y-%m-%d')>'2020-05-01' -fmt '{},{}'.format(iso(mtime),name) Y:\ : PASSED 30,205 scanned, 2 matched, 0 errors Total Time : 4s STATUS : PASSED Copy the files based on date (2020 YearMay month first date) from Y: to Z: c:\XCP>xcp copy -match "strftime(ctime,'%Y-%m-%d')>'2020-05-01'" Y: Z:\dest_karthik XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to Calin Salagean [NetApp Inc] until Mon Dec 31 00:00:00 2029 It appears that you are not running XCP as Administrator. To avoid access issues please run XCP as Administrator. 30,205 scanned, 3 matched, 0 copied, 0 errors, 5s xcp copy -match strftime(ctime,'%Y-%m-%d')>'2020-05-01' Y: Z:\dest_karthik : PASSED 30,205 scanned, 3 matched, 2 copied, 0 errors Total Time : 6s STATUS : PASSED c:\XCP> Check the destination Z: c:\XCP>dir Z:\dest_karthik\karthik_test Volume in drive Z is to Volume Serial Number is 80F1-E202 Directory of Z:\dest_karthik\karthik_test 05/26/2020 02:51 PM <DIR> . 05/26/2020 02:50 PM <DIR> .. 05/26/2020 02:51 PM 2,295 testfile.txt 1 File(s) 2,295 bytes 2 Dir(s) 659,316,736 bytes free c:\XCP>
