저장 오류는 메시지 및 해결 방법을 보여 줍니다
오류 조건에 플래그를 지정하면 storage errors show
오류가 발생한 이유와 해결 방법을 결정해야 합니다.
다음 표에는 에서 감지된 백엔드 구성 오류가 나열되어 있으며 각 오류의 원인과 해결 방법에 대한 자세한 정보가 나와 storage errors show
있습니다.
storage errors show 메시지 |
이 메시지에 대한 자세한 내용은 다음을 참조하십시오. |
NAME (Serial #): All paths to this array LUN are connected to the same fault domain. This is a single point of failure` ..
NAME (Serial #), port WWPN1: LUN 1 occurs more than once. LUNs cannot be reused on the same array target port ..
NAME (Serial #): This array LUN is an access control LUN. It is not supported and should be masked off or disabled` ..
NAME (Serial #) This array LUN is configured with conflicting failover modes. Each path to this LUN must use the same mode ..
NAME (Serial #): This Array LUN is only available on one path. Proper configuration requires two paths ..
NAME (Serial #): This array LUN is too large and is not usable. The maximum array LUN size supported is xTB ..
NAME (Serial #): This array LUN is too small and is not usable. The minimum array LUN size supported is 1GB ..
NAME (Serial #): This Array LUN is using multiple LUN IDs. Only one LUN ID per serial number is supported ..
NAME (Serial #): This array LUN is marked foreign and has a reservation ..
