성능이 저하된 ONTAP 시스템 상태에 대한 응답에 대해 자세히 알아보십시오
노드에 대한 경로가 2개인 셸프로 인해 성능이 저하된 시스템 상태의 특정 예를 검토하여 경고에 응답할 때 CLI가 표시되는 내용을 볼 수 있습니다.
ONTAP를 시작한 후 시스템 상태를 확인하고 성능이 저하되었습니다.
cluster1::>system health status show
Status
degraded
경고를 표시하여 문제가 발생한 위치를 확인하고 쉘프 2에서 노드 1에 대한 경로가 2개 있지 않음을 확인할 수 있습니다.
cluster1::>system health alert show
Node: node1
Resource: Shelf ID 2
Severity: Major
Indication Time: Mon Nov 10 16:48:12 2013
Probable Cause: Disk shelf 2 does not have two paths to controller
node1.
Possible Effect: Access to disk shelf 2 via controller node1 will be
lost with a single hardware component failure (e.g.
cable, HBA, or IOM failure).
Corrective Actions: 1. Halt controller node1 and all controllers attached to disk shelf 2.
2. Connect disk shelf 2 to controller node1 via two paths following the rules in the Universal SAS and ACP Cabling Guide.
3. Reboot the halted controllers.
4. Contact support personnel if the alert persists.
경고 ID를 비롯한 추가 정보를 얻기 위해 알림에 대한 세부 정보를 표시합니다.
cluster1::>system health alert show -monitor node-connect -alert-id DualPathToDiskShelf_Alert -instance
Node: node1
Monitor: node-connect
Alert ID: DualPathToDiskShelf_Alert
Alerting Resource: 50:05:0c:c1:02:00:0f:02
Subsystem: SAS-connect
Indication Time: Mon Mar 21 10:26:38 2011
Perceived Severity: Major
Probable Cause: Connection_establishment_error
Description: Disk shelf 2 does not have two paths to controller node1.
Possible Effect: Access to disk shelf 2 via controller node1 will be lost with a single
hardware component failure (e.g. cable, HBA, or IOM failure).
Acknowledge: false
Suppress: false
Policy: DualPathToDiskShelf_Policy
Acknowledger: -
Suppressor: -
Additional Information: Shelf uuid: 50:05:0c:c1:02:00:0f:02
Shelf id: 2
Shelf Name: 4d.shelf2
Number of Paths: 1
Number of Disks: 6
Adapter connected to IOMA:
Adapter connected to IOMB: 4d
Alerting Resource Name: Shelf ID 2
이 알림은 작업 중임을 나타냅니다.
cluster1::>system health alert modify -node node1 -alert-id DualPathToDiskShelf_Alert -acknowledge true
쉘프 2와 노드 1 사이의 케이블 연결을 수정한 다음 시스템을 재부팅합니다. 그런 다음 시스템 상태를 다시 확인하고 상태가 "OK"인지 확인합니다.
Status
OK
관련 정보
