Delete an unread notification
Colaboradores
DELETE /accounts/{account_id}/core/v1/users/{user_id}/unreadNotifications/{unreadNotification_id}
Removes the specified Unread Notification API resource.
account_id
string
path
True
  • example: {{.Account}}
user_id
string
path
True
ID of the containing user resource
string
path
True
ID of the unreadNotification collection to list
Status: 204, Indicates if the unreadNotification resource was deleted.
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
invalidParams
name
string
True
reason
string
True
