List all LDAP groups
Colaboradores
GET /accounts/{account_id}/core/v1/ldapGroups
Returns a JSON array of JSON objects containing the results of the request URL.
account_id
string
path
True
  • example: {{.Account}}
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: id,cn,dn
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
filter
string
query
False
Indicates which fields should be matched in order to return a resource when listing a collection.
Supported operators are:
  • eq - Equality
  • lt/gt - Less than/Greater than
  • lte/gte - Less than or equals to/Greater than or equals to
URL example: "filter=field%20eq%20%27value%27"
OpenAPI examples: "field eq 'value'"
continue
query
False
Indicates the token to resume listing from.
URL examples: "continue="
OpenAPI examples: ""</continue>
Status: 200, Returns a JSON array of JSON objects containing the results of the request URL.
items
array[Any of: ldapGroup_1.0_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-ldapGroups",
  "version": "1.0",
  "items": [
      "4a461f57-70e6-5732-882e-8d5f684f15a1",
      "boulder_sysadmins",
      "cn=boulder_sysadmins,ou=groups,dc=example,dc=com"
      "da4bbb6f-8f2c-57eb-a9cf-6eeffbf9e35d",
      "rtp_sysadmins",
      "cn=rtp_sysadmins,ou=groups,dc=example,dc=com"
  "metadata": {
    "labels": [],
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "type": "https://astra.netapp.io/problems/14",
  "title": "Unauthorized access",
  "detail": "The user isn't enabled.",
  "status": "403"
Status: 406, Not acceptable
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "type": "https://astra.netapp.io/problems/32",
  "title": "Unsupported content type",
  "detail": "The response can't be returned in the requested format.",
  "status": "406"
Status: 500, Internal server error
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "type": "https://astra.netapp.io/problems/34",
  "title": "Internal server error",
  "detail": "The server was unable to process this request.",
  "status": "500"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
  • Conforms to the Astra Metadata Schema
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
type
string
True
  • "application/astra-ldapGroup"
version
string
True
  • "1.0"
id
string
True
cn
string
False
JSON string representing the LDAP group name. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
dn
string
False
JSON string representing the distinguished name of the LDAP group. Defined values are:
  • Conforms to RFC 4514
metadata
type_astra_metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
