List all upgrades
Colaboradores
GET /accounts/{account_id}/core/v1/upgrades
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: id,componentName,upgradeVersion
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
filter
string
query
False
Indicates which fields should be matched in order to return a resource when listing a collection.
Supported operators are:
  • eq - Equality
  • lt/gt - Less than/Greater than
  • lte/gte - Less than or equals to/Greater than or equals to
URL example: "filter=field%20eq%20%27value%27"
OpenAPI examples: "field eq 'value'"
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: upgrade_1.1_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-upgrades",
  "version": "1.1",
  "items": [
      "01982783-b1eb-4dca-a3fe-a385a3186c53",
      "acc",
      "21.07.1"
      "0a5abab2-39b2-4101-87b9-0d9b8f537ca1",
      "acc",
      "21.07.2"
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_stateDetails
type
string
True
title
string
True
detail
string
True
type_astra_label
name
string
True
value
string
True
type_astra_metadata_update
  • Conforms to the Astra Metadata Schema If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
type
string
True
  • "application/astra-upgrade"
version
string
True
  • "1.0"
  • "1.1"
id
string
True
componentName
string
True
JSON string containing the name of the type of software that can be upgraded. Defined values are:
  • "acc"
  • "acs"
  • "trident"
  • "kubernetes"
componentInstance
string
True
JSON string containing the URI of the component that can be upgraded. Defined values are:
  • Minimum length: 3
  • Maximum length: 4095
componentID
string
True
JSON string containing a globally unique identifier of the component that can be upgraded. Defined values are:
  • Conforms to the Astra Identifier Schema
upgradeVersion
string
True
JSON string containing the SemVer of the software image file that can be upgraded to. Defined values are:
  • Conforms to the SemVer Schema
currentVersion
string
True
JSON string containing the current SemVer of the entity to be upgraded. Defined values are:
dependencies
array[string]
True
JSON array of JSON strings, each containing the UUID of an upgrade that must be completed before this upgrade can proceed. Used to determine which upgrades will be performed as prerequisites and in which order. Defined values are:
state
string
True
JSON string containing a value indicating the operational state of the upgrade. If auto-upgrade is enabled, upgrades will start in the "scheduled" state. Otherwise, upgrades will start in the "proposed" state. Defined values are:
  • "unavailable" - The upgrade is not available at this time
  • "proposed" - The upgrade is proposed but will not automatically run until approved
  • "scheduled" - The upgrade is approved but is not ready to be installed due to dependencies, time windows, or available resources
  • "running" - The upgrade is in progress
  • "complete" - The upgrade has completed
  • "failed" - The upgrade did not complete
stateDesired
string
True
JSON string containing a value indicating the desired state for "state". This field is only included when the user can directly request a change in the state of the resource. Defined values are:
  • "proposed" - The upgrade is not approved and must not be performed
  • "scheduled" - The upgrade is approved and must be performed in the specified time window
  • "running" - The upgrade must be performed immediately, regardless of the time window
stateDetails
array[type_astra_stateDetails]
True
JSON array of JSON objects that lists additional details about the current "state". If no details are available, this array will be empty.
  • Minimum Items: 0
metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
