Modify a subscription
Colaboradores
PUT /accounts/{account_id}/core/v1/subscriptions/{subscription_id}
Replaces the entire stored resource with the supplied JSON request body while preserving key values that are not user-modifiable.
Side Effects
  • If the user cancels the subscription, the PUT endpoint must be called with "status": "inactive".
  • When the status is set to "inactive", the pending charges for this subscription are sent to Zuora and the Zuora subscription will be marked as "inactive" in some way.
account_id
string
path
True
  • example: {{.Account}}
subscription_id
string
path
True
ID of the subscription collection to list
Request Body
Side Effects
type
string
True
  • "application/astra-subscription"
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
id
string
False
customerProfileID
string
False
JSON string containing the customer profile ID from Authorize.net, which was invoked by the UI, is not set for the trial term. Returns an empty string during read operation, if not set. Defined values are:
  • Minimum length: 0
  • Maximum length: 63
paymentFirstName
string
False
JSON string containing a user-specified long-form first name used for payment billing. Specified only when the subscription is being rebilled. Defined values are:
  • Minimum length: 1
paymentLastName
string
False
JSON string containing a user-specified long-form last name used for payment billing. Specified only when the subscription is being rebilled. Defined values are:
  • Minimum length: 1
paymentAddress
paymentAddress
False
JSON object containing a collection of JSON strings specifying a billing address. Specified only when the subscription is being rebilled. If this key exists, all six of the contained JSON strings will be present. If nothing was provided by the user, the string will be empty.
paymentProfileID
string
False
JSON string containing the payment profile ID from Authorize.net that was invoked by the UI, not set for trial term. Returns an empty string during read operation if not set. Defined values are:
  • Minimum length: 0
paymentExpiry
string
False
JSON string containing a timestamp indicating when the payment method expires. This is obtained from authorize.net](http://authorize.net) and is set by the UI. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema This field is not returned for trial terms.
purchaseOrderNumber
string
False
JSON string containing the purchase order number for the payment method. Defined values are:
  • Minimum length: 1
  • Maximum length: 31
marketplace
string
False
JSON string indicating the marketplace for an account where payments will be recorded. Defined values:
  • "netapp"
  • "azure"
  • "aws"
  • "gcp"
licenseSN
string
False
JSON string containing the license serial number for the payment method. Defined values are:
  • Minimum length: 1
terms
string
False
JSON string indicating the current tier of the account. Defined values are:
  • "trial"
  • "paid"
status
string
False
JSON string indicating the current status of the subscription. Defined values are:
  • "active"
  • "inactive"
appLimit
number
False
JSON number indicating the application limit for this subscription. Value of -1 indicates no limit.
namespaceLimit
number
False
JSON number indicating the namespace limit for this subscription. Value of -1 indicates no limit.
subscriptionPeriod
number
False
JSON number indicating the subscription period. Value of -1 indicates no limit. Unit: days
gracePeriod
number
False
JSON number indicating the grace period after the trial subscription has expired or a paid subscription is canceled. Unit: days
reminderBeforePeriod
number
False
JSON number indicating the number of days before the end of the trial subscription we should start notifying the customer. Value of -1 indicates N/A. Unit: days
onboardStatus
string
False
JSON string indicating the current status of customer onboarding. Valid values are "not started", "in progress", "success", "failed". Defined values are:
  • "not started"
  • "in progress"
  • "success"
  • "failed"
costPerAppUnit
number
False
JSON number indicating the cost per app unit. For a trial version, the value would be 0. Unit: US dollars
costPerNamespaceUnit
number
False
JSON number indicating the cost per namespace unit. For a trial version, the value would be 0. Unit: US dollars
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-subscription",
  "version": "1.2",
  "customerProfileID": "2157047189",
  "paymentProfileID": "E7CEB0A9F1BECA32A02493E1B31D5955",
  "paymentExpiry": "2022-05-01T00:00:00Z"
Status: 204, Indicates if the subscription resource was updated.
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
paymentAddress
addressCountry
string
True
JSON string containing the country name or country code associated with the postal address, as specified in ISO 3166 Alpha-2. Defined values are:
  • Minimum length: 0
  • Maximum length: 2
addressLocality
string
True
JSON string containing the locality (for example, city) associated with the postal address. Defined values are:
  • Minimum length: 0
addressRegion
string
True
JSON string containing the region (for example, state) associated with the postal address. Defined values are:
  • Minimum length: 0
postalCode
string
True
JSON string containing the postal code associated with the postal address. Defined values are:
  • Minimum length: 0
streetAddress1
string
True
JSON string containing the street address associated with the postal address. Defined values are:
  • Minimum length: 0
streetAddress2
string
False
JSON string containing optional ancillary street address information, post office box, and more. Defined values are:
  • Minimum length: 0
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
modificationTimestamp
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
