Retrieve an application asset for an application snapshot and app
Colaboradores
GET /accounts/{account_id}/k8s/v1/apps/{app_id}/appSnaps/{appSnap_id}/appAssets/{appAsset_id}
Returns the stored Application Asset API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
app_id
string
path
True
ID of the containing app resource
appSnap_id
string
path
True
ID of the containing appSnap resource
appAsset_id
string
path
True
ID of the appAsset collection to list
Status: 200, Returns the stored Application Asset API resource in the JSON response body.
type
string
True
  • "application/astra-appAsset"
version
string
True
  • "1.0"
  • "1.1"
id
string
True
assetType
string
True
JSON string containing a value indicating what type of asset is being described as obtained from Kubernetes. Defined values are:
  • Minimum length: 1
  • Maximum length: 254
creationTimestamp
string
True
JSON string containing a timestamp indicating when the Kubernetes metadata was created. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
GVK
GVK
True
JSON object containing a Kubernetes group/version/kind.
resource
type_json
False
JSON object containing the entire content of the Kubernetes resource definition.
assetID
string
True
JSON string containing an identifier assigned by Kubernetes. Defined values are:
  • Conforms to the Astra Identifier Schema
labels
array[labels]
True
JSON array of JSON objects, each containing a Kubernetes labels associated with the asset. If no details are available, this array will be empty.
  • Minimum items: 0
assetName
string
True
JSON string containing a name assigned by Kubernetes. Defined values are:
  • Minimum length: 1
namespace
string
False
JSON string containing a namespace assigned by Kubernetes. Defined values are:
  • Minimum length: 1
metadata
type_astra_metadata
True
  • Conforms to the Astra Metadata Schema
  "type": "application/astra-appAsset",
  "version": "1.1",
  "id": "6415e851-b820-553b-9432-ebd057d1917d",
  "assetType": "Pod",
  "creationTimestamp": "2020-08-06T12:24:52.256624Z",
  "GVK": {
    "group": "apps",
    "kind": "Pod",
    "version": "v1"
  "assetID": "93ec0c61-d993-4aa1-bb08-f4dcdd5e97f6",
  "labels": [
      "name": "app",
      "value": "mediawiki"
      "name": "pod-template-hash",
      "value": "69c6fcf864"
  "assetName": "mediawiki-69c6fcf864-2wx6l",
  "namespace": "wiki",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
GVK
group
string
False
JSON string containing a group identifier assigned by Kubernetes. Defined values are:
  • Minimum length: 1
kind
string
False
JSON string containing a kind identifier assigned by Kubernetes. Defined values are:
  • Minimum length: 1
version
string
False
JSON string containing a version identifier assigned by Kubernetes. Defined values are:
  • Minimum length: 1
type_json
labels
name
string
True
JSON string containing the label name Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • Defined regex is: "^([\S.]{1,253}\/)?([a-z0-9A-Z_.-]){1,63}$"
value
string
True
JSON string containing the label value Defined values are:
  • Minimum length: 1
  • Defined regex is: "^([a-z0-9A-Z_.-]){1,63}$"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
