Configurar relações de replicação no FSX para sistemas de arquivos ONTAP
Você pode encontrar informações adicionais sobre as opções de configuração do SnapMirror na documentação do ONTAP em "Fluxo de trabalho de replicação do SnapMirror (NetApp.com)".
Fonte FSX para sistema de arquivos ONTAP:
FsxId00fa9e3c784b6abbb -
Fonte SVM:
sapcc-hana-svm -
Escolha o sistema de arquivos FSX for ONTAP:
FsxId05f7f00af49dc7a3e -
SVM-alvo:
sapcc-backup-target-zone5
Peer FSX para sistemas de arquivos ONTAP
FsxId00fa9e3c784b6abbb::> network interface show -role intercluster
Logical Status Network Current Current Is
Vserver Interface Admin/Oper Address/Mask Node Port Home
inter_1 up/up 10.1.1.57/24 FsxId00fa9e3c784b6abbb-01
e0e true
inter_2 up/up 10.1.2.7/24 FsxId00fa9e3c784b6abbb-02
e0e true
2 entries were displayed.
FsxId05f7f00af49dc7a3e::> network interface show -role intercluster
inter_1 up/up 10.1.2.144/24 FsxId05f7f00af49dc7a3e-01
e0e true
inter_2 up/up 10.1.2.69/24 FsxId05f7f00af49dc7a3e-02
e0e true
FsxId05f7f00af49dc7a3e::> cluster peer create -address-family ipv4 -peer-addrs 10.1.1.57, 10.1.2.7 Notice: Use a generated passphrase or choose a passphrase of 8 or more characters. To ensure the authenticity of the peering relationship, use a phrase or sequence of characters that would be hard to guess. Enter the passphrase: Confirm the passphrase: Notice: Now use the same passphrase in the "cluster peer create" command in the other cluster.
peer-addrs São IPs de cluster do cluster de destino.
FsxId00fa9e3c784b6abbb::> cluster peer create -address-family ipv4 -peer-addrs 10.1.2.144, 10.1.2.69
FsxId00fa9e3c784b6abbb::> cluster peer show
Peer Cluster Name Cluster Serial Number Availability Authentication
FsxId05f7f00af49dc7a3e 1-80-000011 Available ok
SVMs pares
FsxId05f7f00af49dc7a3e::> vserver peer create -vserver sapcc-backup-target-zone5 -peer-vserver sapcc-hana-svm -peer-cluster FsxId00fa9e3c784b6abbb -applications snapmirror Info: [Job 41] 'vserver peer create' job queued
FsxId00fa9e3c784b6abbb::> vserver peer accept -vserver sapcc-hana-svm -peer-vserver sapcc-backup-target-zone5 Info: [Job 960] 'vserver peer accept' job queued
FsxId05f7f00af49dc7a3e::> vserver peer show
Peer Peer Peering Remote
Vserver Vserver State Peer Cluster Applications Vserver
peer-source-cluster
peered FsxId00fa9e3c784b6abbb
snapmirror sapcc-hana-svm
Crie um volume de destino
Você deve criar o volume de destino com o tipo DP para sinalizá-lo como um destino de replicação.
FsxId05f7f00af49dc7a3e::> volume create -vserver sapcc-backup-target-zone5 -volume PFX_data_mnt00001 -aggregate aggr1 -size 100GB -state online -policy default -type DP -autosize-mode grow_shrink -snapshot-policy none -foreground true -tiering-policy all -anti-ransomware-state disabled [Job 42] Job succeeded: Successful
Crie uma política do SnapMirror
A política SnapMirror e a regra adicionada definem a retenção e o rótulo SnapMirror para identificar snapshots que devem ser replicados. Ao criar a política SnapCenter mais tarde, você deve usar o mesmo rótulo.
FsxId05f7f00af49dc7a3e::> snapmirror policy create -policy snapcenter-policy -tries 8 -transfer-priority normal -ignore-atime false -restart always -type vault -vserver sapcc-backup-target-zone5
FsxId05f7f00af49dc7a3e::> snapmirror policy add-rule -vserver sapcc-backup-target-zone5 -policy snapcenter-policy -snapmirror-label snapcenter -keep 14
FsxId00fa9e3c784b6abbb::> snapmirror policy showVserver Policy Policy Number Transfer
Name Name Type Of Rules Tries Priority Comment
snapcenter-policy vault 1 8 normal -
SnapMirror Label: snapcenter Keep: 14
Total Keep: 14
Criar relacionamento SnapMirror
Agora, a relação entre o volume de origem e destino é definida, bem como o tipo XDP e a política que criamos anteriormente.
FsxId05f7f00af49dc7a3e::> snapmirror create -source-path sapcc-hana-svm:PFX_data_mnt00001 -destination-path sapcc-backup-target-zone5:PFX_data_mnt00001 -vserver sapcc-backup-target-zone5 -throttle unlimited -identity-preserve false -type XDP -policy snapcenter-policy Operation succeeded: snapmirror create for the relationship with destination "sapcc-backup-target-zone5:PFX_data_mnt00001".
Inicialize o SnapMirror
Com este comando, a replicação inicial é iniciada. Esta é uma transferência completa de todos os dados do volume de origem para o volume de destino.
FsxId05f7f00af49dc7a3e::> snapmirror initialize -destination-path sapcc-backup-target-zone5:PFX_data_mnt00001 -source-path sapcc-hana-svm:PFX_data_mnt00001 Operation is queued: snapmirror initialize of destination "sapcc-backup-target-zone5:PFX_data_mnt00001".
Você pode verificar o status da replicação com o snapmirror show comando.
FsxId05f7f00af49dc7a3e::> snapmirror show
Progress
Source Destination Mirror Relationship Total Last
Path Type Path State Status Progress Healthy Updated
XDP sapcc-backup-target-zone5:PFX_data_mnt00001
Uninitialized
Transferring 1009MB true 02/24 12:34:28
Progress
Snapmirrored
Idle - true -
