Link entre o Site B e o ONTAP Mediator inativo e o Site A inativo
Para verificar a conexão do ONTAP Mediator ou do ONTAP Cloud Mediator, use o snapmirror mediator show comando. Se o status da conexão for inacessível e o Site B não conseguir acessar o Site A, você terá uma saída semelhante à mostrada abaixo. Siga as etapas da solução para restaurar a conexão.
Usando o comando snapmirror mediator show de saída do ONTAP Cloud Mediator:
cluster::> snapmirror mediator show Mediator Address Peer Cluster Connection Status Quorum Status Type ---------------- ---------------- ----------------- ------------- ------- 0.0.0.0 C1_cluster unreachable true cloud
Usando o comando snapmirror mediator show de saída do ONTAP Mediator:
cluster::> snapmirror mediator show Mediator Address Peer Cluster Connection Status Quorum Status ---------------- ---------------- ----------------- ------------- 10.237.86.17 C1_cluster unreachable true SnapMirror consistency group relationship status is out of sync. C2_cluster::> snapmirror show -expand Source Destination Mirror Relationship Total Last Path Type Path State Status Progress Healthy Updated ----------- ---- ------------ ------- -------------- --------- ------- -------- vs0:/cg/src_cg_1 XDP vs1:/cg/dst_cg_1 Snapmirrored OutOfSync - false - vs0:zrto_cg_655724_188a_RW1 XDP vs1:zrto_cg_655755_188c_DP1 Snapmirrored OutOfSync - false - vs0:zrto_cg_655733_188a_RW2 XDP vs1:zrto_cg_655762_188c_DP2 Snapmirrored OutOfSync - false - vs0:zrto_cg_655739_188b_RW1 XDP vs1:zrto_cg_655768_188d_DP1 Snapmirrored OutOfSync - false - vs0:zrto_cg_655748_188b_RW2 XDP vs1:zrto_cg_655776_188d_DP2 Snapmirrored OutOfSync - false - 5 entries were displayed. Site B cluster is unable to reach Site A. C2_cluster::> cluster peer show Peer Cluster Name Cluster Serial Number Availability Authentication ------------------------- --------------------- -------------- -------------- C1_cluster 1-80-000011 Unavailable ok
Forçar um failover para habilitar a e/S do local B e, em seguida, estabelecer uma relação rto zero do local B para o local A. conclua as etapas a seguir para executar um failover forçado no local B.
Desmapear todos os LUNs pertencentes ao grupo de consistência do Site B falhará, portanto, você deve primeiro modificar o igroup para remover o SVM do par de replicação e, em seguida, excluir o mapeamento de LUN.
Exemplo:
C1_cluster::> lun mapping show
Vserver Path Igroup LUN ID Protocol
vs0 /vol/cg1_lun/lun_1 igroup1 0 mixed
vs0 /vol/cg1_lun/lun_2 igroup1 1 mixed
2 entries were displayed.
C1_cluster::> lun mapping delete -path /vol/cg1_lun/lun_5 -igroup igroup1
Error: command failed: The peer cluster is unreachable and a SnapMirror
Mediator is not configured. The configuration is locked for replicated
objects in this Vserver peer relationship on both clusters. The only
supported configuration change is to manually disable replication on
both sides of the relationship, after which configuration changes are
supported.
C1_cluster::> igroup modify -igroup igroup1 -replication-peer -
C1_cluster::> lun mapping delete -path /vol/cg1_lun/lun_1 -igroup igroup1
1 entries were displayed.
Exclua a relação do grupo de consistência do SnapMirror usando a opção forçar.
Digite o comando SnapMirror Break (
snapmirror break -destination_path svm:_volume_) nos volumes constituintes do grupo de consistência para converter volumes de DP para RW, para ativar e/S do local B.Você deve emitir o comando SnapMirror Break para cada relacionamento no grupo consistência. Por exemplo, se houver três volumes no grupo consistência, você emitirá o comando para cada volume.
Inicialize os nós do local A para criar uma relação rto zero do local B para o local A..
Libere o grupo de consistência com relação-info-only no Site A para reter o snapshot comum e desmapear os LUNs pertencentes ao grupo de consistência.
Converta volumes no local A de RW para DP configurando uma relação de nível de volume usando a política de sincronização ou a política de sincronização.
Emita o
snapmirror resynccomando para sincronizar as relações. -
Excluir as relações SnapMirror com a política de sincronização no local A..
Libere as relações do SnapMirror com a política de sincronização usando somente relacionamento verdadeiro no local B..
Crie uma relação de grupo de consistência entre o local B e o local A..
No cluster de origem, ressincronize o grupo de consistência. Verifique se o estado do grupo de consistência está em sincronia.
Reescaneie os caminhos de e/S LUN do host para restaurar todos os caminhos para os LUNs.
