Veja as informações de ajuda na CLI do ONTAP SP/BMC
Colaboradores netapp-aaron-holt netapp-sumathi netapp-aoife netapp-aherbin
A ajuda on-line exibe os comandos e opções da CLI do SP/BMC.
Sobre esta tarefa
Esta tarefa aplica-se tanto ao SP como ao BMC.
Passos
  1. Para exibir informações de ajuda para os comandos SP/BMC, digite o seguinte:
    Para acessar a ajuda do SP…​ Para acessar a ajuda do BMC…​
    Digite help no prompt SP.
    Digite system no prompt BMC.
    O exemplo a seguir mostra a ajuda online da CLI do SP.
    SP> help
    date - print date and time
    exit - exit from the SP command line interface
    events - print system events and event information
    help - print command help
    priv - show and set user mode
    sp - commands to control the SP
    system - commands to control the system
    version - print SP version
    O exemplo a seguir mostra a ajuda online da CLI do BMC.
    BMC> system
    system acp - acp related commands
    system battery - battery related commands
    system console - connect to the system console
    system core - dump the system core and reset
    system cpld - cpld commands
    system log - print system console logs
    system power - commands controlling system power
    system reset - reset the system using the selected firmware
    system sensors - print environmental sensors status
    system service-event - print service-event status
    system fru - fru related commands
    system watchdog - system watchdog commands
    BMC>
  2. Para exibir informações de ajuda para a opção de um comando SP/BMC, digite help antes ou depois do comando SP/BMC.
    O exemplo a seguir mostra a ajuda online da CLI do SP para o comando SP events.
    SP> help events
    events all - print all system events
    events info - print system event log information
    events newest - print newest system events
    events oldest - print oldest system events
    events search - search for and print system events
    O exemplo a seguir mostra a ajuda online da CLI do BMC para o comando BMC system power.
    BMC> system power help
    system power cycle - power the system off, then on
    system power off - power the system off
    system power on - power the system on
    system power status - print system power status
    BMC>
Saiba mais sobre os comandos descritos neste procedimento no "Referência do comando ONTAP".
Informações relacionadas
