Active IQ Unified Manager 9.10
Create Resource Pool dialog box
Contributors netapp-manini
You can use the Create Resource Pool dialog box to name and describe a new resource pool and to add aggregates to and delete aggregates from that resource pool.
Resource Pool Name
The text boxes enable you to add the following information to create a resource pool:
Enables you to specify a resource pool name.
Enables you to describe a resource pool.
Members
Displays the members of the resource pool. You can also add and delete members.
Command buttons
The command buttons enable you to perform the following tasks:
  • Add
    Opens the Aggregates dialog box so that you can add aggregates from a specific cluster to the resource pool. You can add aggregates from different clusters, but the same aggregates cannot be added to more than one resource pool.
  • Remove
    Enables you to remove selected aggregates from the resource pool.
  • Create
    Creates the resource pool. This button is not enabled until information has been entered in the Resource Pool Name or Description fields.
  • Cancel
    Discards the changes and closes the Create Resource Pool dialog box.
