Active IQ Unified Manager
9.7
What Event Management System events are
The Event Management System (EMS) collects event data from different parts of the ONTAP kernel and provides event forwarding mechanisms. These ONTAP events can be reported as EMS events in Unified Manager. Centralized monitoring and management eases configuration of critical EMS events and alert notifications based on these EMS events.
The Unified Manager address is added as a notification destination to the cluster when you add the cluster to Unified Manager. An EMS event is reported as soon as the event occurs in the cluster.
There are two methods for receiving EMS events in Unified Manager:
  • A certain number of important EMS events are reported automatically.
  • You can subscribe to receive individual EMS events.
The EMS events that are generated by Unified Manager are reported differently depending on the method in which the event was generated:
Functionality Automatic EMS messages Subscribed EMS messages
Available EMS events
Subset of EMS events
All EMS events
EMS message name when triggered
Unified Manager event name (converted from EMS event name)
Non-specific in the format “Error EMS received”. The detailed message provides the dot-notation format of the actual EMS event
Messages received
As soon as the cluster has been discovered
After adding each required EMS event to Unified Manager, and after the next 15 minute polling cycle
Event life cycle
Same as other Unified Manager events: New, Acknowledged, Resolved, and Obsolete states
The EMS event is made obsolete after the cluster is refreshed, after 15 minutes, from when the event was created
Captures events during Unified Manager downtime
Yes, when the system starts up it communicates with each cluster to acquire missing events
No
Event details
Suggested corrective actions are imported directly from ONTAP to provide consistent resolutions
Corrective actions not available in Event Details page
Note
Some of the new automatic EMS events are Informational events that indicate that a previous event has been resolved. For example, the “FlexGroup Constituents Space Status All OK” Informational event indicates that the “FlexGroup Constituents Have Space Issues” Error event has been resolved. Informational events cannot be managed using the same event life cycle as other event severity types, however, the event is obsoleted automatically if the same volume receives another “Space Issues” Error event.
