Active IQ Unified Manager
9.7
Add Annotation dialog box
The Add Annotation dialog box enables you to create custom annotations that you can associate with clusters, volumes, and storage virtual machines (SVMs) through annotation rules.
You must have the Application Administrator or Storage Administrator role.
  • Annotation Name
    Specifies the name of the annotation. You must enter a unique name for the annotation.
  • Description
    Specifies a meaningful description of the annotation.
Annotation Values
  • Add
    Adds a new value to the selected annotation.
  • Delete
    Deletes the selected value for an annotation.
Command buttons
  • Save and Close
    Saves the new annotation and closes the Add Annotation dialog box dialog box.
  • Cancel
    Closes the Add Annotation dialog box without saving your changes.
