Active IQ Unified Manager
9.7
Add Annotation Rule dialog box
The Add Annotation Rule dialog box enables you to create annotation rules in Unified Manager to dynamically annotate storage objects.
You must have the Application Administrator or Storage Administrator role.
  • Name
    Specifies the name of the annotation rule.
  • Target Object Type
    Specifies the type of storage objects (storage virtual machines (SVMs), volumes, or clusters) that you want to annotate.
  • Apply Annotation
    Specifies the annotation and the value you can use to annotate storage objects when all conditions are met.
  • Conditions
    Specifies conditions that determine which storage objects you can annotate.
Command buttons
  • Save and Add
    Adds the annotation rule you created and enables you to add another annotation rule without closing the dialog box.
  • Add
    Adds the annotation rule and closes the Add Annotation Rule dialog box.
  • Cancel
    Cancels the changes and closes the Add Annotation Rule dialog box.
  • Add Condition
    Adds a condition to define the annotation rule.
  • Add Condition Group
    Adds a condition group to define conditions for the annotation rule.
