Active IQ Unified Manager
9.7
Create SnapMirror Policy dialog box
The Create SnapMirror Policy dialog box enables you to create a policy to set the priority for SnapMirror transfers. You use policies to maximize the efficiency of transfers from the source to the destination.
  • Destination Cluster
    The name of the cluster you selected in the SnapMirror tab of the Configure Protection dialog box.
  • Destination SVM
    The name of the SVM you selected in the SnapMirror tab of the Configure Protection dialog box.
  • Policy Name
    The name you provide for the new policy. Policy names can consist of the characters A through Z, a through z, 0 through 9, period (.), hyphen (-), and underscore (_).
  • Transfer Priority
    The priority at which a transfer runs for asynchronous operations. You can select either Normal or Low. Transfer relationships with policies that specify a normal transfer priority run before those with policies that specify a low transfer priority.
  • Comment
    An optional field in which you can add comments about the policy.
  • Transfer Restart
    Indicates what restart action to take when a transfer is interrupted by an abort operation or any type of failure, such as a network outage. You can select one of the following:
    • Always
      Specifies that a new Snapshot copy is created before restarting a transfer, then, if one exists, the transfer is restarted from a checkpoint, followed by an incremental transfer from the newly created Snapshot copy.
    • Never
      Specifies that interrupted transfers are never restarted.
Command buttons
The command buttons enable you to perform the following tasks:
  • Cancel
    Discards the selections and closes the Configure Protection dialog box.
  • Apply
    Applies your selections and begins the protection process.
