Active IQ Unified Manager
9.7
Create SnapVault Policy dialog box
The Create SnapVault Policy dialog box enables you to create a policy to set the priority for SnapVault transfers. You use policies to maximize the efficiency of transfers from the primary to the secondary volume.
  • Destination Cluster
    The name of the cluster that you selected in the SnapVault tab of the Configure Protection dialog box.
  • Destination SVM
    The name of the SVM that you selected in the SnapVault tab of the Configure Protection dialog box.
  • Policy Name
    The name you provide for the new policy. Policy names can consist of the characters A through Z, a through z, 0 through 9, period (.), hyphen (-), and underscore (_).
  • Transfer Priority
    The priority at which the transfer is run. You can select either Normal or Low. Transfer relationships with policies that specify a normal transfer priority run before those with policies that specify a low transfer priority. The default setting is Normal.
  • Comment
    An optional field in which you can a add comment of up to 255 characters about the SnapVault policy.
  • Ignore Access Time
    Specifies whether incremental transfers are ignored for files that have only their access time changed.
  • Replication Label
    Lists in a table the rules associated with Snapshot copies selected by ONTAP that have a specific replication label in a policy. The following information and actions are also available:
    • Command buttons
      The command buttons enable you to perform the following actions:
      • Add
        Enables you to create a Snapshot copy label and retention count.
      • Edit Retention Count
        Enables you to change the retention count for an existing Snapshot copy label. The retention count must be a number between 1 and 251. The sum of all retention counts for all rules cannot exceed 251.
      • Delete
        Enables you to delete an existing Snapshot copy label.
    • Snapshot Copy Label
      Displays the Snapshot copy label. If you select one or more volumes with the same local Snapshot copy policy, an entry for each label in the policy is displayed. If you select multiple volumes that have two or more local Snapshot copy policies, the table displays all labels from all policies
    • Schedule
      Displays the schedule associated with each Snapshot copy label. If a label has more than one schedule associated with it, the schedules for that label are displayed in a comma-separated list. If you select multiple volumes with the same label but with different schedules, the schedule displays “Various” to indicate that more than one schedule is associated with the selected volumes.
    • Destination Retention Count
      Displays the number of Snapshot copies with the specified label that are retained on the SnapVault secondary. Retention counts for labels with multiple schedules displays the sum of retention counts of each label and schedule pair. If you select multiple volumes with two or more local Snapshot copy policies, the retention count is empty.
