Active IQ Unified Manager
9.7
Disable Events dialog box
The Disable Events dialog box displays the list of event types for which you can disable events. You can disable events for an event type based on a particular severity or for a set of events.
You must have the Application Administrator or Storage Administrator role.
Event Properties area
The Event Properties area specifies the following event properties:
  • Event Severity
    Enables you to select events based on the severity type, which can be Critical, Error, Warning, or Information.
  • Event Name Contains
    Enables you to filter events whose name contains the specified characters.
  • Matching events
    Displays the list of events matching the event severity type and the text string you specify.
  • Disable events
    Displays the list of events that you have selected for disabling.
    The severity of the event is also displayed along with the event name.
Command buttons
The command buttons enable you to perform the following tasks for the selected events:
  • Save and close
    Disables the event type and closes the dialog box.
  • Cancel
    Discards the changes and closes the dialog box.
