Active IQ Unified Manager
9.7
Edit Group Action dialog box
You can edit the group action that you created for groups by using the Edit Group Action dialog box.
You must have the Application Administrator or Storage Administrator role.
  • Action Name
    Displays the name of the group action.
  • Description
    Displays the description of the group action.
  • Group
    Displays the name of the group selected.
  • Action type
    Displays the type of group action. You cannot change the action type. However, you can modify the parameters that you used to configure the group action.
Command buttons
  • Save
    Saves the changes you made to the group action.
  • Cancel
    Closes the Edit Group Action dialog box without saving your changes.
