Active IQ Unified Manager
9.7
Edit Volume Thresholds dialog box
You can configure alerts to send notifications when an event related to a volume's capacity is generated, and you can take corrective actions for the event. For example, for the Volume Full threshold, you can configure an alert to send notification when the condition persists over a specified period.
You must have the Application Administrator or Storage Administrator role.
The Edit Volume Thresholds dialog box enables you to configure volume-level thresholds that are applied to the selected volumes. When thresholds are configured at the volume level, they take priority over the group-level thresholds or the global-level threshold values.
You can configure threshold settings for capacity, Snapshot copies, qtree quota, growth, and inodes at the volume level. When a group action of volume threshold type is configured, the group action threshold values are used for settings that are not configured at the volume level. When no group action of volume threshold type is configured, areas in Edit Volume Thresholds dialog box that are not configured, use global threshold values.
Capacity area
The Capacity area enables you to set the following volume capacity threshold conditions:
  • Space Nearly Full
    Specifies the percentage at which a volume is considered to be nearly full. It also displays the size of the volume corresponding to the specified threshold value.
    You can also use the slider to set the threshold value.
  • Space Full
    Specifies the percentage at which a volume is considered full. It also displays the size of the volume corresponding to the specified threshold value.
  • Days Until Full
    Specifies the number of days remaining before the volume reaches full capacity.
Snapshot Copies
The Snapshot Copies area enables you to set the following threshold conditions for the Snapshot copies in the volume.
  • Snapshot Reserve Full
    Specifies the percentage at which the space reserved for Snapshot copies is considered full.
  • Days Until Full
    Specifies the number of days remaining before the space reserved for Snapshot copies reaches full capacity.
  • Count
    Specifies the number of Snapshot copies on a volume that are considered to be too many.
Qtree Quota area
The Qtree Quota area enables you to set the following qtree quota threshold conditions for the selected volumes:
  • Nearly Overcommitted
    Specifies the percentage at which a volume is considered to be nearly overcommitted by qtree quotas.
  • Overcommitted
    Specifies the percentage at which a volume is considered to be overcommitted by qtree quotas.
Growth area
The Growth area enables you to set the following threshold condition for volume growth:
  • Growth Rate
    Specifies the percentage at which a volume's growth rate is considered to be normal before the system generates a Volume Growth Rate Abnormal event.
  • Growth Rate Sensitivity
    Specifies the factor that is applied to the standard deviation of a volume's growth rate. If the growth rate exceeds the factored standard deviation, a Volume Growth Rate Abnormal event is generated.
    A lower value for growth rate sensitivity indicates that the volume is highly sensitive to changes in the growth rate.
    Note
    If you modify the growth rate sensitivity for volumes at the global threshold level, the change is also applied to the growth rate sensitivity for aggregates at the global threshold level.
Inodes area
The Inodes area enables you to set the following threshold conditions for inodes:
  • Nearly Full
    Specifies the percentage at which a volume is considered to have consumed most of its inodes.
    You can also use the sliders to set the threshold value.
  • Full
    Specifies the percentage at which a volume is considered to have consumed all of its inodes.
Command buttons
The command buttons enable you to perform the following tasks for a selected volume:
  • Restore to Defaults
    Enables you to restore the threshold values to one of the following:
    • Group values, if the volume belongs to a group and that group has a volume threshold action type.
    • Global values, if the volume does not belong to any group or if it belongs to a group that does not have a volume threshold action type.
  • Save
    Saves all the threshold settings.
  • Save and Close
    Saves all the threshold settings and then closes the dialog box.
  • Cancel
    Ignores the changes (if any) to the threshold settings and closes the dialog box.
