Active IQ Unified Manager
9.7
Enclosures events
Enclosures events provide you with information about the status of disk shelf enclosures in your data center so that you can monitor for potential problems. Events are grouped by impact area and include the event and trap name, impact level, source type, and severity.
Impact area: availability
Event name(Trap name) Impact level Source type Severity
Disk Shelf Fans Failed(ocumEvtShelfFanFailed)
Incident
Storage shelf
Critical
Disk Shelf Power Supplies Failed(ocumEvtShelfPowerSupplyFailed)
Incident
Storage shelf
Critical
Disk Shelf Multipath Not Configured(ocumDiskShelfConnectivityNotInMultiPath)
This event does not apply to:
  • Clusters that are in a MetroCluster configuration
  • The following platforms: FAS2554, FAS2552, FAS2520, and FAS2240
Risk
Node
Warning
Disk Shelf Path Failure(ocumDiskShelfConnectivityPathFailure)
Risk
Storage Shelf
Warning
Impact area: configuration
Disk Shelf Discovered(Not applicable)
Event
Node
Information
Disk Shelves Removed(Not applicable)
Event
Node
Information
