Active IQ Unified Manager
9.7
Reorder Group Actions dialog box
You can use the Reorder Group Actions dialog box to change the ranks of one or more group actions. The position of a group action in the grid determines the rank for the group action.
You must have the Application Administrator or Storage Administrator role.
  • Rank
    Specifies the order of the group action to be applied on storage objects in a group.
  • Name
    Specifies the name of the group action.
  • Action Type
    Specifies the type of action that you can perform on the storage objects in a group.
  • Associated Group
    Specifies the name of the group for which the group actions are defined.
