Active IQ Unified Manager
9.7
Workflow Automation page
The Workflow Automation page enables you to configure the settings to integrate OnCommand Workflow Automation with Unified Manager. You can also add, modify, or delete the settings.
You must have the Application Administrator or Storage Administrator role.
Unified Manager Database User
This area enables you to enter the credentials of a database user that is required for pairing Unified Manager with Workflow Automation:
  • Name
    Enables you to specify the user name of a database user that can be used to access data in the Unified Manager database. By default, no database user is selected. You can select a database user from the drop-down list.
  • Password
    Enables you to specify a password for the specified user name.
OnCommand Workflow Automation Credentials
This area enables you to enter the credentials of a Workflow Automation account that is required for pairing with Unified Manager:
  • Hostname or IP Address
    Specifies the name or IP address of the Workflow Automation host server, which is used to pair with Unified Manager.
  • Port
    Displays the required the port number of the Workflow Automation host server, which is 443.
  • Username
    Enables you to specify a user name that can be used to log in to Workflow Automation.
  • Password
Command buttons
The command buttons enable you to remove, save, or cancel the setup options:
  • Remove Setup
    Removes the Workflow Automation setup from Unified Manager.
  • Save
    Saves the configuration settings for the selected option.
