Identifying the best node for a busy LIF using ONTAP System Manager
You can display information about all the ports in a cluster. You can view information such as the network port role (cluster, data, or node-management), link status, maximum transmission unit (MTU), speed setting and operational status, and the port's interface group, if applicable.
Steps
Open ONTAP System Manager.
From the Home tab, double-click the storage system.
In the navigation pane, expand the Nodes hierarchy.
To find the active connections on a node, in the navigation pane, select the icon for a node.
Click the name link of a node and then click Configuration > Ports/Adapters.
Note the highest client count by node.
