Active IQ Unified Manager 9.8
9.8
Annotate SVM dialog box
The Annotate Storage VM dialog box enables you to manually annotate storage objects. You can select either a single SVM or multiple SVMs and annotate with a specific value pair from the existing list of annotations.
You must have the Application Administrator or Storage Administrator role.
  • Annotation=Value Pairs
    Enables you to select the required annotation for the selected SVM.
  • Apply
    Applies the selected annotation to the SVM.
  • Cancel
    Closes the Annotate Storage VM dialog box without saving your changes.
