Active IQ Unified Manager 9.8
9.8
Edit Group dialog box
The Edit Group dialog box enables you to change the name and description of a group.
You must have the Application Administrator or Storage Administrator role.
  • Group Name
    Displays the name of the group. When changing the group name, you must not use an existing group name.
  • Description
    Provides a meaningful description of the group. You can edit this field when you want to change the current description of the group.
Command buttons
The command buttons enable you to save or cancel changes you make to the group.
  • Save
    Saves the changes you made and closes the dialog box.
  • Cancel
    Closes the Edit Group dialog box without saving your changes.
