Active IQ Unified Manager 9.8
9.8
MetroCluster Connectivity events
Connectivity events provide you with information about the connectivity between the components of a cluster and between clusters in a MetroCluster configuration so that you can monitor for potential problems. Events are grouped by impact area and include the event and trap name, impact level, source type, and severity.
Impact area: availability
Event name(Trap name) Impact level Source type Severity
All Inter-Switch Links Down(ocumEvtMetroClusterAllISLBetweenSwitchesDown)
Incident
MetroCluster inter-switch connection
Critical
All Links Between MetroCluster Partners Down(ocumEvtMetroClusterAllLinksBetweenPartnersDown)
Incident
MetroCluster relationship
Critical
FC-SAS Bridge To Storage Stack Link Down(ocumEvtBridgeSasPortDown)
Incident
MetroCluster bridge stack connection
Critical
MetroCluster Configuration Switched Over((ocumEvtMetroClusterDRStatusImpacted)
Risk
Warning
MetroCluster Configuration Partially Switched Over(ocumEvtMetroClusterDRStatusPartiallyImpacted)
Risk
MetroCluster Disaster Recovery Capability Impacted(ocumEvtMetroClusterDRStatusImpacted)
Risk
Critical
MetroCluster Partners Not Reachable Over Peering Network(ocumEvtMetroClusterPartnersNotReachableOverPeeringNetwork)
Incident
Critical
Node To FC Switch All FC-VI Interconnect Links Down(ocumEvtMccNodeSwitchFcviLinksDown)
Incident
MetroCluster node switch connection
Critical
Node To FC Switch One Or More FC-Initiator Links Down(ocumEvtMccNodeSwitchFcLinksOneOrMoreDown)
Risk
Warning
Node To FC Switch All FC-Initiator Links Down(ocumEvtMccNodeSwitchFcLinksDown)
Incident
Critical
Switch To FC-SAS Bridge FC Link Down (ocumEvtMccSwitchBridgeFcLinksDown)
Incident
MetroCluster switch bridge connection
Critical
Inter Node All FC VI InterConnect Links Down (ocumEvtMccInterNodeLinksDown)
Incident
Inter-node connection
Critical
Inter Node One Or More FC VI InterConnect Links Down (ocumEvtMccInterNodeLinksOneOrMoreDown)
Risk
Warning
Node To Bridge Link Down (ocumEvtMccNodeBridgeLinksDown)
Incident
Node bridge connection
Critical
Node to Storage Stack All SAS Links Down ( ocumEvtMccNodeStackLinksDown)
Incident
Node stack connection
Critical
Node to Storage Stack One Or More SAS Links Down ( ocumEvtMccNodeStackLinksOneOrMoreDown)
Risk
Warning
