Active IQ Unified Manager 9.8
9.8
Remote Authentication page
You can use the Remote Authentication page to configure Unified Manager to communicate with your authentication server to authenticate remote users who attempt to log into the Unified Manager web UI.
You must have the Application Administrator or Storage Administrator role.
After you select the Enable remote authentication checkbox, you can enable remote authentication using an authentication server.
  • Authentication Service
    Enables you to configure the management server to authenticate users in directory service providers, such as Active Directory, OpenLDAP, or specify your own authentication mechanism. You can specify an authentication service only if you have enabled remote authentication.
    • Active Directory
      • Administrator Name
        Specifies the administrator name of the authentication server.
      • Password
        Specifies the password to access the authentication server.
      • Base Distinguished Name
        Specifies the location of the remote users in the authentication server. For example, if the domain name of the authentication server is ou@domain.com, then the base distinguished name is cn=ou,dc=domain,dc=com.
      • Disable Nested Group Lookup
        Specifies whether to enable or disable the nested group lookup option. By default this option is disabled. If you use Active Directory, you can speed up authentication by disabling support for nested groups.
      • Use Secure Connection
        Specifies the authentication service used for communicating with authentication servers.
    • OpenLDAP
      • Bind Distinguished Name
        Specifies the bind distinguished name that is used along with the base distinguished name to find remote users in the authentication server.
      • Bind Password
        Specifies that Secure LDAP is used for communicating with LDAPS authentication servers.
    • Others
        Specifies the bind distinguished name that is used along with the base distinguished name to find remote users in the authentication server that you have configured.
      • Bind Password
      • Protocol Version
        Specifies the Lightweight Directory Access Protocol (LDAP) version that is supported by your authentication server. You can specify whether the protocol version must be automatically detected or set the version to 2 or 3.
      • User Name Attribute
        Specifies the name of the attribute in the authentication server that contains user login names to be authenticated by the management server.
      • Group Membership Attribute
        Specifies a value that assigns the management server group membership to remote users based on an attribute and value specified in the user's authentication server.
      • UGID
        If the remote users are included as members of a GroupOfUniqueNames object in the authentication server, this option enables you to assign the management server group membership to the remote users based on a specified attribute in that GroupOfUniqueNames object.
      • Member
        Specifies the attribute name that your authentication server uses to store information about the individual members of a group.
      • User Object Class
        Specifies the object class of a user in the remote authentication server.
      • Group Object Class
        Specifies the object class of all groups in the remote authentication server.
    Note
    If you want to modify the authentication service, ensure that you delete any existing authentication servers and add new authentication servers.
Authentication Servers area
The Authentication Servers area displays the authentication servers that the management server communicates with to find and authenticate remote users. The credentials for remote users or groups are maintained by the authentication server.
  • Command buttons
    Enables you to add, edit, or delete authentication servers.
    • Add
      Enables you to add an authentication server.
      If the authentication server that you are adding is part of a high-availability pair (using the same database), you can also add the partner authentication server. This enables the management server to communicate with the partner when one of the authentication servers is unreachable.
    • Edit
      Enables you to edit the settings for a selected authentication server.
    • Delete
      Deletes the selected authentication servers.
  • Name or IP Address
    Displays the host name or IP address of the authentication server that is used to authenticate the user on the management server.
  • Port
    Displays the port number of the authentication server.
  • Test Authentication
    This button validates the configuration of your authentication server by authenticating a remote user or group.
    While testing, if you specify only the user name, the management server searches for the remote user in the authentication server, but does not authenticate the user. If you specify both the user name and password, the management server searches and authenticates the remote user.
    You cannot test the authentication if remote authentication is disabled.
