Active IQ Unified Manager 9.8
9.8
Reorder Annotation Rule dialog box
You can use the Reorder Annotation Rule dialog box to specify the order in which you want annotation rules to be applied to storage objects.
Command buttons
You must have the Application Administrator or Storage Administrator role.
  • Save
    Saves the changes you made to the annotation rules and closes the Reorder Annotation Rule dialog box.
  • Cancel
    Closes the Reorder Annotation Rule dialog box without saving the changes you made.
List View
  • Rank
    Displays the order in which the annotation rules will be applied to the storage objects.
  • Name
    Displays the name of the annotation rule.
  • Target Object Type
    Displays the type of storage object to which the annotation rule is applied.
  • Associated Annotation
    Displays the name of the annotation that is applied to the storage object.
  • Associated Annotation Value
    Displays the annotation value for the storage object.
