Active IQ Unified Manager 9.8
9.8
Volume Thresholds page
The Volume Thresholds page enables you to configure global health threshold values for monitored volumes. You can set thresholds for individual volumes or for all the volumes globally. When you configure the options globally, the default values of all objects are modified. However, if the default values have been changed at the object level, the global values are not modified.
You must have the Application Administrator or Storage Administrator role.
Events are generated when a threshold is breached. You can take corrective actions for such events.
You can set thresholds for the following: capacity, volume Snapshot copies, qtree quotas, volume growth, and inodes.
Capacity area
The Capacity area enables you to set the following volume capacity threshold conditions. Note that when Autogrow is enabled on a volume that capacity thresholds are considered breached based on the maximum volume size set by autogrow, not based on the original volume size.
  • Space Nearly Full
    Specifies the percentage at which a volume is considered to be nearly full:
    • Default value: 80 percent
      The value for this threshold must be lower than the value for the Volume Full threshold in order for the management server to generate an event.
    • Event generated: Volume Nearly Full
    • Event severity: Warning
  • Space Full
    Specifies the percentage at which a volume is considered full:
    • Default value: 90 percent
    • Event generated: Volume Full
    • Event Severity: Error
  • Days Until Full
    Specifies the number of days remaining before the volume reaches full capacity:
    • Default value: 15 (this is also the minimum value)
    • Event generated: Volume Days Until Full
    • Event severity: Error
Snapshot copies area
The Snapshot copies area enables you to set the following threshold conditions for the Snapshot copies in the volume:
  • Snapshot Reserve Full
    Specifies the percentage at which the space reserved for Snapshot copies is considered full:
    • Event generated: Volume Snapshot Reserve Full
  • Days Until Full
    Specifies the number of days remaining before the space reserved for Snapshot copies reaches full capacity:
    • Default value: 7
    • Event generated: Volume Snapshot Reserve Days Until Full
  • Count
    Specifies the number of Snapshot copies on a volume that are considered to be too many:
    • Default value: 1000
    • Event generated: Too Many Snapshot Copies
    • Event severity: Error The number of Snapshot copies that are considered the maximum per volume before Unified Manager triggers an event is lower than the ONTAP maximum:
    ONTAP Maximum Unified Manager Maximum
    FlexVol volumes running ONTAP 9.3 or earlier and FlexGroup volumes running ONTAP 9.7 or earlier
    255
    250
    FlexVol volumes running ONTAP 9.4 or greater and FlexGroup volumes running ONTAP 9.8 or greater
    1023
    1000
Qtree Quota area
The Qtree Quota area enables you to set the following volume quota threshold conditions:
  • Nearly Overcommitted
    Specifies the percentage at which a volume is considered to be nearly overcommitted by qtree quotas:
    • Default value: 95 percent
    • Event generated: Volume Qtree Quota Nearly Overcommitted
  • Overcommitted
    Specifies the percentage at which a volume is considered to be overcommitted by qtree quotas:
    • Default value: 100 percent
    • Event generated: Volume Qtree Quota Overcommitted
Growth area
The Growth area enables you to set the following threshold conditions for volume growth:
  • Growth Rate
    Specifies the percentage at which a volume's growth rate is considered to be normal before the system generates a Volume Growth Rate Abnormal event:
    • Default value: 1 percent
    • Event generated: Volume Growth Rate Abnormal
  • Growth Rate Sensitivity
    Specifies the factor that is applied to the standard deviation of a volume's growth rate. If the growth rate exceeds the factored standard deviation, a Volume Growth Rate Abnormal event is generated.
    A lower value for growth rate sensitivity indicates that the volume is highly sensitive to changes in the growth rate. The range for the growth rate sensitivity is 1 through 5.
    • Default value: 2
    Note
    If you modify the growth rate sensitivity for volumes at the global threshold level, the change is also applied to the growth rate sensitivity for aggregates at the global threshold level.
Inodes area
The Inodes area enables you to set the following threshold conditions for inodes:
  • Nearly Full
    Specifies the percentage at which a volume is considered to have consumed most of its inodes:
    • Event generated: Inodes Nearly Full
  • Full
    Specifies the percentage at which a volume is considered to have consumed all of its inodes:
    • Event generated: Inodes Full
