Configuring volume health thresholds for groups
PDF of this doc site
- Online help
- Monitor and manage cluster performance
- Monitor and manage cluster health
Creating your file...
Your file is ready
You can configure group-level volume health thresholds for capacity, Snapshot copies, qtree quotas, growth, and inodes.
Before you begin
You must have the Application Administrator or Storage Administrator role.
About this task
The volume health threshold type of group action is applied only on volumes of a group.
Steps
In the left navigation pane, click Storage Management > Groups.
In the Group Actions tab, click Add.
Enter a name and description for the group action.
From the Group drop-down box, select a group for which you want to configure group action.
Select Action Type as the volume health threshold.
Select the category for which you want to set the threshold.
Enter the required values for the health threshold.
Click Add.
