Active IQ Unified Manager 9.9
9.9
Add Cluster dialog box
Contributors netapp-maumita
You can add an existing cluster so that you can monitor the cluster and obtain information about its health, capacity, configuration, and performance.
You can add a cluster by specifying the following values:
  • Host Name or IP Address
    Enables you to specify the host name (preferred) or the IP address (IPv4 or IPv6) of the cluster-management LIF that is used to connect to the cluster. By specifying the host name, you will be able to match the name of the cluster across the web UI, rather than trying to correlate an IP address on one page to a host name on another page.
  • User Name
    Enables you to specify a user name that can be used to log in to the cluster.
  • Password
    Enables you to specify a password for the specified user name.
  • Port
    Enables you to specify the port number used to connect to the cluster. The default port is 443 for HTTPS.
