Active IQ Unified Manager 9.9
9.9
Annotate Volume dialog box
Contributors netapp-maumita
The Annotate Volume dialog box enables you to manually annotate storage objects. You can select either a single volume or multiple volumes and annotate with a specific value pair from the existing list of annotations.
You must have the Application Administrator or Storage Administrator role.
  • Annotation=Value Pairs
    Enables you to select the required annotation for the selected volume.
  • Apply
    Applies the selected annotation to the volume.
  • Cancel
    Closes the Annotate Volume dialog box without saving your changes.
