Edit Cluster dialog box
The Edit Cluster dialog box enables you to modify the connection settings of an existing cluster, including the IP address, port, and protocol.
You can edit the following fields:
Host Name or IP Address
Enables you to specify the FQDN, short name, or the IP address (IPv4 or IPv6) of the cluster-management LIF that is used to connect to the cluster.
User Name
Enables you to specify a user name that can be used to log in to the cluster.
Password
Enables you to specify a password for the specified user name.
Port
Enables you to specify the port number used to connect to the cluster. The default port is 443 for HTTPS.
