Active IQ Unified Manager 9.9
9.9
Edit Group Rule dialog box
Contributors netapp-maumita
You can edit the group rules you created to include the maximum number of storage objects in a group.
You must have the Application Administrator or Storage Administrator role.
  • Rule Name
    Displays the name of the rule.
  • Target Object Type
    Displays the storage object to be added to a selected group. You cannot change the object type.
  • Associated Group
    Displays the associated group. You can select a different group for the group rule.
  • Condition
    Displays the list of conditions for a selected group. You can edit the conditions. The storage objects are either removed or added to a selected group based on the changes.
Command buttons
  • Save
    Saves the changes you made and closes the dialog box.
  • Cancel
    Closes the Edit Group Rule dialog box without saving your changes.
