Edit Resource Pool dialog box
You can use the Edit Resource Pool dialog box to change the name and description of an existing resource pool. For example, if the original name and description is inaccurate or incorrect, you can change them so they are more precise.
Text boxes
The text boxes enable you to change the following information for the selected resource pool:
Resource Pool Name
Enables you to enter a new name.
Enables you to enter a new description.
Command buttons
The command buttons enable you to perform the following tasks:
Save
Saves the changes to the resource pool name and description.
Cancel
Discards the changes and closes the Edit Resource Pool dialog box.
