Active IQ Unified Manager 9.9
9.9
Volume capacity fields
Contributors netapp-maumita
The following fields are available in the Capacity: All Volumes view and can be used in custom views and in reports.
  • Volume
    The volume name.
  • Daily Growth Rate %
    The growth rate that occurs every 24 hours in the volume.
  • Days To Full
    The estimated number of days remaining before the volume reaches full capacity.
  • Available Data %
    The available data capacity in a volume as a percentage.
  • Available Data Capacity
    The available data capacity in a volume.
  • Used Data %
    The used data in a volume as a percentage.
  • Used Data Capacity
    The used data capacity in a volume.
  • Total Data Capacity
    The total data capacity (used plus available) in a volume.
  • Logical Space Used
    The logical space used by data in this volume without applying the savings from using ONTAP storage efficiency technologies.
  • Snapshot Overflow %
    The percentage of the data space that is consumed by Snapshot copies.
  • Snapshot Reserve Available %
    The amount of space available for Snapshot copies in the volume as a percentage.
  • Snapshot Reserve Available Capacity
    The amount of space available for Snapshot copies in the volume.
  • Snapshot Reserve Used %
    The amount of space used by Snapshot copies in the volume as a percentage.
  • Snapshot Reserve Used Capacity
    The amount of space used by Snapshot copies in the volume.
  • Snapshot Reserve Total Capacity
    Displays the total Snapshot copy capacity in the volume.
  • Quota Committed Capacity
    The space reserved for quotas in the volume.
  • Quota Overcommitted Capacity
    The amount of space that can be used for quotas before the system generates the Volume Quota Overcommitted event.
  • Total Number Of Inodes
    The number of inodes in the volume.
  • Inode Utilization %
    The percentage of inode space used in the volume.
  • Thin Provisioned
    Whether space guarantee is set for the selected volume. Valid values are Yes and No.
  • Space Guarantee
    The storage guarantee option that is associated with the volume.
  • Autogrow
    Whether the volume automatically grows in size when it is out of space.
  • Snapshot Autodelete
    Whether automatic deletion of Snapshot copies is enabled or disabled.
  • Deduplication
    Whether deduplication is enabled or disabled for the volume.
  • Compression
    Whether compression is enabled or disabled for the volume.
  • State
    The state of the volume that is being exported.
  • Protection Role
    The protection role that is set for the volume.
  • SnapLock Type
    Whether the volume is a SnapLock or non-SnapLock volume.
  • SnapLock Expiry Date
    The SnapLock expiration date.
  • Tiering Policy
    The tiering policy set for the volume. Valid when deployed on FabricPool-enabled aggregates only.
  • Caching Policy
    The caching policy that is associated with the selected volume.
    The policy provides information about how Flash Pool caching occurs for the volume. See the Health: All Volumes view for more information on caching policies.
  • Cache Retention Priority
    The priority used for retaining cached pools.
  • Storage VM
    The name of the storage virtual machine (SVM) that contains the volume.
  • Cluster
    The name of the cluster on which the volume resides. You can click the cluster name to navigate to that cluster's health details page.
  • Cluster FQDN
    The fully qualified domain name (FQDN) of the cluster.
