Active IQ Unified Manager 9.9
9.9
Volume compliance categories
Contributors netapp-maumita
This table describes the volume encryption parameters that Unified Manager evaluates to determine whether the data on your volumes is adequately protected from being accessed by unauthorized users.
Note that the volume encryption parameters do not affect whether the cluster or storage VM is considered compliant.
Parameter Description
Software Encrypted
Displays the number of volumes that are protected using NetApp Volume Encryption (NVE) or NetApp Aggregate Encryption (NAE) software encryption solutions.
Hardware Encrypted
Displays the number of volumes that are protected using NetApp Storage Encryption (NSE) hardware encryption.
Software and Hardware Encrypted
Displays the number of volumes that are protected by both software and hardware encryption.
Not Encrypted
Displays the number of volumes that are not encrypted.
