Changing or canceling a scheduled maintenance window
PDF of this doc site
Online help
Monitor and manage cluster performance
Monitor and manage cluster health
Creating your file...
If you have configured a Unified Manager maintenance window to occur in the future, you can change the start and end times or cancel the maintenance window from occurring.
Before you begin
You must have the Application Administrator or Storage Administrator role.
About this task
Canceling a currently running maintenance window is useful if you have completed cluster maintenance before the scheduled maintenance window end time and you want to start receiving events and alerts from the cluster again.
Steps
In the left navigation pane, click Storage Management > Cluster Setup.
In the Maintenance Mode column for the cluster:
If you want to… | Perform this step… |
Change the timeframe for a scheduled maintenance window |
Extend the length of an active maintenance window |
Cancel a scheduled maintenance window |
Select the slider button and move it to the left. |
Cancel an active maintenance window |
