Active IQ Unified Manager 9.9
9.9
Monitoring Storage VMs using Relationships page
You can monitor your storage VM disaster recovery relationships from the Relationships page in the PROTECTION section of the INVENTORY. By default, the Relationships page lists only the top level relationships as the constituent relationships filter is applied.
Before you begin
You must have the Application Administrator or Storage Administrator role.
About this task
You use filters to view the storage VM disaster recovery relationships.
Steps
  1. In the left navigation pane, click PROTECTION > Relationships.
    The page displays all type of relationships: volume and storage VM relationships.
  2. Click Filter, and then select Relationship Object Type and Storage VM to view only storage VM disaster recovery relationships.
  3. Click Apply Filter.
    Note
    You should clear the constituent relationships filter to view all the protection relationships.
    The page displays only storage VM disaster recovery relationships.
