Digital Advisor
Learn about wellness widget in Digital Advisor
Contributors manishc netapp-manishc netapp-barbe FarheenViquas
Wellness widget provides detailed information about your storage system. It provides information about different attributes of your storage system, such as performance and efficiency, capacity, configuration settings, security vulnerabilities, support renewals, and others.
wellness workflow
The wellness widget also provides information about the risks and the actions that should be taken to mitigate the risk for each wellness attribute. The following are the types of risks and the associated consequence for each risk:
Risk Type Consequence
Critical
Data loss, data corruption, cluster data outage, personal safety issue, or potential legal compliance issue.
High
Short-term loss of data access or prolonged loss of node redundancy.
Medium
Performance degradation or short-term loss of node redundancy.
Low
Low impact scenarios
Best Practice
Deviations from documented best practices
You can view the following video to understand the importance of the wellness attributes:
