• Release notes
  • Get started
    • Provision watchlist
  • Use Digital Advisor
    • Analyze wellness attributes
    • Analyze the sustainability of storage system
    • Generate an upgrade plan
    • View system details
    • Identify system requirements proactively
    • Identify configuration deviation
    • Improve the efficiency and performance of storage system
    • Analyze the health of storage system
    • Upgrade to optimize your install base
      • Update AFF and FAS firmware using Ansible Playbook
        • Install and execute AFF and FAS firmware Ansible automation package (beginners)
    • Integrate data using APIs
    • Generate custom reports
  • Knowledge and support
