Learn about Sustainability dashboard features in Digital Advisor
Sustainability dashboard provides an environmental assessment of your storage systems and actionable insights for improvement in the form of NetApp's recommended actions.
AutoSupport should be enabled for accurate calculation of the sustainability score. |
Sustainability score: Displays the total score indicating the environmental sustainability of your storage systems. You can assess the sustainability level of your storage systems based on the following range:
76 - 100: Indicates that sustainability is a top priority.
51 - 75: Indicates a high level of investment in sustainability initiatives.
26 - 50: Indicates good progress towards sustainability initiatives.
Less than 25: Indicates the need for improvement in sustainability practices.
You can see the graphical representation of the score for up to 5 weeks, which is updated on a weekly basis. You can also see the reason for the increase or decrease in the sustainability score by hovering over the graph.
Environmental indicators: Displays projections for your power, direct carbon usage, and heat emission to evaluate the environmental health of your storage systems. These projections are based on actual power, if unavailable, typical power values. You can view these projections monthly, quarterly, or yearly by selecting the desired option from the drop-down in the top right corner of this section.
Carbon mitigation percentages: Displays the percentage of carbon mitigation at each site/city, and the presented baseline values are based on your location. You can adjust the carbon mitigation percentage for specific sites by selecting the
icon located next to the percentage values, and the carbon numbers will automatically adjust accordingly.
Recommended actions: Displays the list of recommended actions to improve the sustainability score of your storage systems. These actions can be taken immediately, or later.
For more information on how to improve the sustainability score, see Improve sustainability score.
Systems: Displays environmental parameters in the table that can help in identifying clusters for moving to more efficient storage. From this table, you can:
View the sustainability score at cluster level, select the cluster name to access ClusterViewer, take specific recommended actions to improve the sustainability. For more information, see Improve sustainability score at cluster level.
Enable monitoring from the Real-time power column to view the real-time power details at the cluster level. For more information, see Data Infrastructure Insights.
