The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Generate a config drift timeline report in Digital Advisor
Your file is ready
You can compare the AutoSupport data of the last 90 days and generate a report that provides information about the events and the configuration deviations that have occurred.
Steps
From the left pane, select Config Drift.
Select the Drift Timeline report type.
Generate a drift timeline report
You can generate a report immediately or you can schedule the report to be generated on a weekly or monthly basis.
To generate a report immediately
To schedule the report to be generated on a weekly or monthly basis
Select a category and provide the requested values for the report.
Select Include only drifts option to download only the configuration deviation changes.
