Manage AI Data Engine workspaces
A workspace is a set of data sources (volumes) that AI Data Engine (AIDE) uses to build and refresh a metadata catalog for a particular project or use case. As a storage administrator, you can use ONTAP System Manager to monitor workspace health, adjust configuration, control data sources, manage users, and delete workspaces when they are no longer needed.
You need storage administrator privileges to manage workspaces.
Review workspace status
Review workspace health, capacity usage, and metadata status to ensure the Metadata Engine is operating as expected and not consuming unexpected resources.
From ONTAP System Manager, in the navigation pane select Data engine > Workspaces.
Review the summary at the top of the page for total workspaces, overall workspace health, and capacity usage.
For workspace-specific information, select a workspace name. On the Overview tab confirm:
Workspace state and size.
Data containers (volumes) included in the workspace.
Item counts and last updated time per data source.
Any workspace-level warnings.
If a workspace or data collection shows an error state, verify that all source volumes are online and accessible. -
Select the Data collections tab to see:
All data collections associated with this workspace.
State (such as
PublishedorError), size, and last updated time.System Manager is read-only for data collections. Data engineers can create and manage data collections in AIDE Console.
Select the Users tab to view:
The list of users with access to this workspace.
Select the Activity tab to see events and jobs related to this workspace only.
Edit workspace properties and refresh schedule
You can adjust a workspace's name, description, refresh interval, and (if licensed) its guardrail policy.
From Data engine > Workspaces, select
next to a workspace and select Edit. -
Edit workspace properties:
Update Name and Description as needed.
Adjust the Refresh interval (metadata update frequency) within the allowed range (hours and days).
If an AIDE premium services license is installed, you can select Guardrail policy.
Select Save.
Changes to the refresh interval or metadata processing might affect how often remote SnapMirror relationships are updated for this workspace. |
Add data containers to an existing workspace
You can add additional mounted volumes (local or from a peered remote cluster) so that their metadata is included in the workspace catalog.
From Data engine > Workspaces, do one of the following:
Select
next to the workspace and select Add data containers. -
Open the workspace, select the Overview tab, and then select Add in the data containers section.
In the Add data containers to workspace dialog:
Locate local volumes on the AIDE cluster.
Expand peered clusters to select remote volumes (remote volumes require cluster and SVM peering).
Only eligible, online volumes that are not globally excluded and not already part of the workspace can be selected. -
If you are prompted for remote volume mapping:
Select the target Storage VM on the AIDE cluster to receive SnapMirror destinations for the chosen remote volumes.
Select Add.
Use the workspace Activity tab or Data engine > Activity to track metadata extraction and any SnapMirror initialization for new data sources.
Remove data containers from a workspace
You might remove a data container when it is no longer relevant to the workspace's purpose or if you want to reduce the scope of metadata management for that workspace. Removing a data container stops metadata refresh for that volume and removes its metadata from the metadata catalog.
Do not delete a source volume from ONTAP that has been added to a workspace. If you delete the volume, the workspace will enter a failed state. Always remove the data container from the workspace first before deleting any underlying ONTAP volumes. |
Navigate to Data engine > Workspaces and select the workspace that contains the data container.
On the Overview tab, locate the data container to remove.
Select Remove next to the data container.
Review the confirmation dialog and select Remove.
Removing a data container from a workspace does not delete the underlying ONTAP volume or its SnapMirror relationship. It only affects metadata usage within AIDE. |
Manage workspace users
You can grant or revoke access for data engineer and data scientist users to a workspace. These users are defined in your identity provider (OIDC) and mapped to ONTAP roles. See assign users to workspaces documentation to learn how to manage user access.
Delete a workspace
You can delete a workspace to remove the workspace definition and associated AIDE metadata. Any data collections and vector embeddings tied to the workspace are also removed.
Underlying ONTAP data (volumes, SnapMirror relationships) are not deleted. |
In Data engine > Workspaces, do one of the following:
Delete a single workspace, select
and select Delete. -
Delete multiple workspaces, select the checkboxes for the workspaces, and then select Delete.
In the confirmation dialog, review the impacts of the action before proceeding:
Workspace metadata is permanently deleted.
Data collections and embeddings associated with the workspace are permanently deleted.
There is no soft-delete or restore option. -
Select the checkbox to confirm your understanding, and select Delete.
