View AI Data Engine system and cluster status
As a storage administrator, you can use ONTAP System Manager to access the dashboard and display the cluster status. This is a good first step before beginning your AI Data Engine (AIDE) administrative tasks or if you suspect an operational issue.
You need storage administrator privileges to perform AIDE ONTAP-related administrative tasks.
Monitor AIDE health and capacity from the dashboard
Connect to ONTAP System Manager using the cluster management address:
https://$FQDN_OR_IP/ -
Sign in with an administrator account.
Select Dashboard in the left navigation pane.
Review the Health tile:
Confirm overall cluster health.
Verify the Data compute nodes count and status.
Check for alerts:
Data compute node issues or connectivity problems
Workspaces or data collections in error (for example, collection publishing failures)
Review the Capacity tile:
Note total cluster capacity and used capacity.
For AIDE clusters, verify:
Capacity used by AIDE metadata and application volumes (metadata Storage VM)
Capacity used by workspaces and data collections (if available)
Optionally review Network and Performance tiles to understand cluster-wide behavior that might impact AIDE workloads (for example, network congestion or protection lag).
View data compute node health and utilization
In the navigation pane, select Cluster and then Overview.
Select the Data compute tab.
This tab shows all data compute nodes in the cluster with:
Node name, model, serial, and software version
Overall node state
CPU and memory utilization
GPU utilization (if GPUs are present)
Any node-level error indicators
Expand a data compute node to open the detailed view and check:
System CPU and memory usage
GPU memory usage
Reported hardware or service issues
Select Cabling on the Cluster > Overview page to verify that data compute nodes are correctly cabled to the cluster switches and to identify any port or link issues.
Monitor workspaces and metadata footprint
In the navigation pane, select Data engine and then Workspaces.
Review the workspace summary at the top of the page:
Count of workspaces and their states (for example,
Processing,Healthy,Error). -
Total workspace size.
Percentage of cluster capacity consumed by all workspaces.
Review the workspace grid:
Confirm that critical workspaces show a Healthy state.
Check workspace sizes and capacity consumption.
Look for any workspaces in
Erroror long-runningProcessingstates.
To review details for a specific workspace, select its name:
On the Overview tab, confirm:
Workspace state and size
Data containers (volumes) included and their item counts
Last updated time for each data source
On the Data collections tab, confirm:
Which data collections exist for that workspace (data collections are read-only in System Manager)
Their state, size, and last updated time
On the Users tab, check which AIDE Console users have access.
Monitor metadata Storage VM and AIDE-managed protection
In the navigation pane, select Cluster and then Storage VMs.
Locate the Storage VM with subtype
data-engine(the metadata SVM):-
Confirm that the metadata SVM is online.
Optionally open its details to see counts for:
Volumes
LIFs with type
Data compute network(used for communication between data compute nodes and ONTAP)
Select Protection and then Relationships to view protection for remote data sources used in workspaces:
Identify AIDE-created SnapMirror relationships by naming pattern:
Destination volume:
<source_volume_name>_dest_<source_volume_UUID> -
Policy:
<source_volume_name>_dest_aide_policy_<source_volume_UUID>
Use this view to verify that relationships are healthy and that lag time aligns with workspace refresh expectations.
Do not modify the metadata Storage VM, AIDE-created SnapMirror relationships, or AIDE-managed snapshots (or their schedules) directly in ONTAP. Changes can disrupt AIDE version history. Adjust workspace refresh settings if you need to adjust refresh behavior. |
Review AIDE-related alerts and notifications
In the navigation pane, select Events & Jobs and then System alerts.
Review any active alerts related to:
Data compute node health or connectivity
Data engine networking issues
Workspace or data collection errors
Software version mismatches between ONTAP and the data compute node cluster
As needed, configure notification destinations (for example, email, syslog) in Cluster > Settings > Notification management to ensure AIDE-related alerts are forwarded to your operations tooling.
