AI Data Engine
Manage data sources in AI Data Engine
Contributors netapp-dbagwell
Keep scan coverage aligned with the data you need to analyze. Use the Data sources page to check scan progress, investigate gaps in coverage, and manage which systems and data resources AI Data Engine (AIDE) scans.
View scan status and details
Check scan status to see how scanning is progressing and to identify resources that need attention. Review system-level progress and resource-level details to distinguish scans that are still running from those that are paused or have errors.
AI Data Engine data sources and scan status
If scans stop or pause unexpectedly, check deployment health. Refer to Monitor deployment health and investigate issues.
Steps
  1. From the AI Data Engine UI, select Data sources.
  2. Locate the system you want to review.
  3. Select View details in the system row.
    The detail view shows:
    • A status overview with current scan progress
    • A breakdown of data resource scan states: running, completed, paused, and errors
    • Scan permission mode (for example, "Scan without write permissions")
      If scan errors appear, expand the error details to see which data resources (volumes, shares, buckets, or schemas) are affected and the reason for the failure.
Pause scanning
Temporarily stop scanning a system when you don't want AI Data Engine to scan it. The system stays connected, and you can resume scanning later.
Steps
  2. Locate the system you want to pause.
  4. Select the actions menu next to the data resource.
  5. Select Pause.
Resume scanning
Resume scanning when you're ready for AI Data Engine to scan a paused system again.
Steps
  2. Locate the paused system.
  5. Select Resume.
Scan all data resources
Refresh metadata across a system after significant data changes so that your analysis reflects the updated data. Use this action to request an immediate scan of all data resources on the system.
Steps
  2. Locate the system you want to scan.
  3. Select the actions menu next to the system.
  4. Select Scan all volumes (there is an equivalent option in the actions menu for shares, buckets, or schemas).
Retry failed scans
Restore scan coverage for resources that could not be scanned successfully. First resolve the cause of the failure, such as a credential issue, network error, or permission problem, and then retry the failed scans.
Steps
  2. Locate the system with failed scans.
  4. Select Retry all scans.
Edit CIFS credentials
Maintain or restore access to SMB shares when the scan account's credentials change or authentication fails. Update the SMB (CIFS) credentials that AI Data Engine uses to authenticate to the shares.
Note If the share uses Kerberos authentication, AI Data Engine authenticates with a ticket from the keytab, and no password is stored in the data source. Refer to Kerberos authentication for SMB/CIFS shares in AI Data Engine.
Steps
  2. Locate the SMB system.
  4. Select Edit CIFS credentials.
  5. Enter the updated username and password, then select Save.
Enable or disable access to DP volumes
Include or exclude replicated data in your scan coverage by enabling or disabling access to data protection (DP) volumes. DP volumes are NetApp SnapMirror destination volumes, and AI Data Engine doesn't scan them by default. You can enable or disable access per system.
Steps
  2. Locate the system.
  4. Select Enable access to DP volumes or Disable access to DP volumes.
Enable or disable scanning of specific shares, buckets, or volumes
Focus scan coverage on the data resources you need to analyze without reconfiguring the entire system. Enable scanning for resources that weren't selected or available during initial setup, and disable scanning for volumes, shares, or buckets that you don't need to analyze.
Steps
  2. Locate the system you want to update.
  4. In the data resources list, locate the volume, bucket, or share you want to change.
  5. Use the Scanning toggle to enable or disable scanning for that resource.
Remove AI Data Engine for a system
Remove a system from active scan coverage when you no longer need AI Data Engine to scan it. Deactivating a system stops all scanning and preserves its configuration. To add the system again, select Activate scans on the system row.
Steps
  2. Locate the system you want to deactivate.
  4. Select Remove system.
